Hi - I need help in changing the side indicator light that is under the side wing mirror on a 2008 XBow.
I can't get the wing mirror off and do not want to force it in case I break anything.
1. Do I need to take the whole mirror assembly off? If so, any guidance on how to do it? I've removed the two screws underneath, and the one small screw next to them...but it still does not budge.
2. If I do not need to remove the mirror assembley then can I just remove the clear glass bit? Is that so..how?
Thanks!
(Sorry tried search buit could not find anything)
